Date/Time: Mon, 25 Nov 2024 14:24:50 +0000
Limit Order Entry with Tick Offset
View Count: 201
[2024-02-26 20:45:09]
User719760 - Posts: 6
Hi
I want to apply Limit Order with Ticks Offeset based on the given below conditions:
The strategy would :
1) apply Limit order to buy entry 10 ticks below when buy entry signal is generated.
2) apply Limit order to sell entry 10 ticks above when sell entry signal is generated.
3) apply Limit order to buy exit 10 ticks above when buy exit signal is generated.
4) apply Limit order to sell exit 10 ticks below when Sell exit signal is generated.
Please Help me how I can do this.
[2024-02-26 20:59:32]
John - SC Support - Posts: 36240
You can use the Spreadsheet System for Trading to do this, where you would define your Entry/Exit signals and setup your order as a Limit and define the offset you want for that Limit order. Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
