Date/Time: Mon, 25 Nov 2024 14:30:12 +0000
Re-center to last price - Automatic range?
View Count: 154
[2024-02-26 18:25:12] |
funbun - Posts: 90 |
The very useful Re-center feature is only available under the "constant range" mode. Is there a way to re-center price while the range stays automatic? Manual streching of the scale every time is a bit inefficient. Thanks team! |
[2024-02-27 15:22:29] |
John - SC Support - Posts: 36242 |
There is not an "automatic" option for re-centering when in "Automatic" scale mode. But you can always reset the scales using any of the available options. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
