Date/Time: Mon, 25 Nov 2024 12:37:05 +0000
Vertical line x hour
View Count: 229
[2024-02-26 15:24:45] |
OriolCasas - Posts: 163 |
Hello, Is there anyway I can track a vertical line at x hour in every session? Without using the Session indicator, I want that to be in a different time. Thank you |
[2024-02-26 17:54:42] |
We are not really understanding what you want. But hopefully the following is what you want: Date-Time Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-04 12:51:19] |
I've done that thanks! Now I would like that it's shown every day on a fixed time. Is that possible? Thank you |
[2024-03-04 17:08:37] |
There is the "Time Line" study that will give you a line every day at a certain time. Refer to the following: Time Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
