Date/Time: Mon, 25 Nov 2024 14:53:29 +0000
Feature Request Study search - internal
View Count: 139
[2024-02-26 13:39:14] |
Technical - Posts: 158 |
I am wading through the complet TPO study and finding it difficult to locate the exact "input name" I wish to alter. Having the ability to search within input and values is vital. Some Global setting have search enables(Thank you!) but it is very important to the studies also. When your complex studies have a zillion options, it is nearly impossible to make quick alterations. Please add a search option or failing that group them by functional subgroups. Failing that at least alphabetize them in parallel with the support documentation. |
