Date/Time: Mon, 25 Nov 2024 14:47:26 +0000
Using mouse to scroll / Cant go backwards on TPO chart
View Count: 305
[2024-02-25 23:17:52]
User409644 - Posts: 45
Hi.
I cant seem to find the mouse settings so that I can use the scroll button to zoom in and out and to also set up using SHift-mouse scroll to scroll horizontaly.
I am also havin g an issue with a tpo chart that is not letting me scroll back to last week to review the week.
How can I fix these issues?
[2024-02-26 17:17:06]
John - SC Support - Posts: 36244
Refer to the following:
General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll)
Make sure the data is loaded going back through end of the previous week. If the data is not loaded, then the chart will not display anything for that time.
Otherwise, there should not be an issue scrolling back to that time. If you have a scrollbar displayed for the chart, then use the scrollbar to scroll back. If the scroll bar is not present, then select "Chart >> Show Scrollbar" to put a checkmark next to that option and have the scrollbar displayed.
