Date/Time: Mon, 25 Nov 2024 14:35:50 +0000
High/Low Prices above the TPO Range
View Count: 215
[2024-02-25 17:09:42] |
Federico Roveda - Posts: 34 |
I'm trying to get the High and Low above every TPO distribution through the Daily OHLC study using the Draw Style = Text. However the study draw the numbers only for the last day and not for the days before. How can I get that? Is there other settings I need to change? Alternatively is there another study to achieve my objective? Thanks Date Time Of Last Edit: 2024-02-25 17:10:29
2024-02-25_18-08-29.png / V - Attached On 2024-02-25 17:09:29 UTC - Size: 245.18 KB - 38 views |
[2024-02-26 17:05:04] |
John - SC Support - Posts: 36242 |
There is not a way to do this. The TPO study is special in how it displays, and therefore has issues with other studies. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart We also tried a few options with the Study/Price Overlay, but nothing worked. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-26 20:20:45] |
@John it would be really appreciated if you could add in the future the possibility to get Hi/Lo (numbers) for each distribution like one can get for TPOC, Singles etc... or support for other functions like the Daily OHLC. Thanks anyway
