Date/Time: Tue, 15 Sep 2026 21:37:26 +0000
[User Discussion] - Swing High and Low using spreadsheets for automated trading
View Count: 1575
[2024-02-25 08:32:15]
aswade3451 - Posts: 20
I am attempting to create a condition that allows a short only if the last swing high is lower that the last swing high. How can I use the spreadsheet to save the value of the current swing high and prior swing high so that I can create a formula to compare them?
Attached I supplied a Screenshot of what I am looking at as well as my spreadsheet...
imageScreenshot 2024-02-25 002916.png / V - Attached On 2024-02-25 08:29:41 UTC - Size: 12.1 KB - 275 views
imageScreenshot 2024-02-25 003017.png / V - Attached On 2024-02-25 08:30:34 UTC - Size: 42.56 KB - 243 views
[2024-02-25 14:38:46]
Sawtooth - Posts: 4352
Use this example:
Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values
[2024-02-27 00:27:12]
Using that example code just copied the study values from the original cells to O3. I need every value > 0 to print on this line only. Unless I can compare the last value >0 to the previous value >0
imageScreenshot 2024-02-26 162337.png / V - Attached On 2024-02-27 00:24:28 UTC - Size: 18.81 KB - 205 views
imageScreenshot 2024-02-26 162405.png / V - Attached On 2024-02-27 00:24:33 UTC - Size: 10.95 KB - 197 views
[2024-02-27 01:05:51]
That example creates a persistent value of the most recent event, and the second most recent event,
and brings both values to row 3, in columns O and P respectively, where you can compare them.
Use a formula like this in O3:
=IF(ID3.SG1@3 > 0, ID3.SG1@3, O4)
Use a formula like this in P3:
=IF(ID3.SG1@3 > 0, O4, P4)
-where the Swing High and Low study is ID3.
This is for the Swing High. Replicate in two other Formula Columns for the Swing Low.
[2024-02-27 02:50:20]
That code does work. I think I was getting confused because didn't have the second subgraph enabled
Code used for swing highs (HH is the Cell for Swing high)
=IF(HH3>0, HH3, O4) --- Cell O
=IF(HH3>0, O4, P4)--- Cell P
=IF(HH3>0, P4, Q4)--- Cell Q
Code used for swing LOWS (HI is the Cell for Swing Low)
=IF(HI3>0, HI3, R4)--- Cell R
=IF(HI3>0, R4, S4)--- Cell S
=IF(HI3>0, S4, T4)--- Cell T
imageScreenshot 2024-02-26 184948.png / V - Attached On 2024-02-27 02:49:54 UTC - Size: 168.73 KB - 243 views
