Date/Time: Wed, 27 Nov 2024 06:48:04 +0000
[User Discussion] - request for a demo feed with level 2/bid/ask/depth update information
View Count: 1390
[2014-08-06 06:31:19] |
ejtrader - Posts: 688 |
SC Team - As you currently don't store bid/ask information as part of scid and during replay though T&S data can be extracted, it doesn't include true bid ask information. This is making it a bit difficult to build a tool and to fine-tune as It can't be replayed back (exactly in the same way - which includes - true level2, depth updated, bid/ask information). In case of Ninja - there are replay files - which pretty much includes everything for this purpose and can be used in replay mode. Probably this is the only thing that I miss in SC compared to Ninja and is making it a bit difficult to fine tune tools in SC that depend on depth updates/ level 2 information. Is it possible for you to provide - FULL replay information ( bid/ask / level 2 / depth updates ) for a single instrument and that too for one single day - that can be used with SC ( Symbol ES ). Potentially you can think of using DTC client/server for this I would imagine. Would you please review and consider this replay for a single day/single instrument that can be used to replay repeatedly as needed? Hope you consider this as a genuine request. Thanks Date Time Of Last Edit: 2014-08-06 06:35:45
[2014-08-06 07:42:41] |
Not sure why you say this. We would expect you would have seen the new feature which stores bid and ask data with every tick. Refer to:New Feature: Historical Bid and Ask Price Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-06 13:13:55] |
SC team - I am referring to BidSize / AskSize ( not type of trade ) which are not stored in scid. All I need is full market information for a single instrument and for a single day ( or even for an hour ) - that I can replay multiple times to fine-tune piece of code. Though it's not really a show stopper - in it's current state ( where I can't replay the full information ) is certainly not ideal. Appreciate if you can think of a way to replay - a single hour of data - for a single instrument - which should include BidSize/AskSize/Depth Updates records/Level 2 information. Thanks - T&S data during live http://screencast.com/t/DZrXYCywjUh ( notice all real numbers for BidSize & AskSize ) - Same data during replay http://screencast.com/t/g40wTqSO3RRJ ( notice all 1's for BidSize & AskSize ) - Also during replay - there are no Depth Update records ( Type -- SC_TS_BIDASKVALUES ) - Also during replay - level 2 information is not available Date Time Of Last Edit: 2014-08-06 13:47:38
[2014-08-06 16:41:39] |
We can offer no help with this now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-06 16:41:58
[2014-08-06 17:00:20] |
Certainly understandable - due to the complexity of this and I would find my way around it. However - being a developer yourself - imagine - lack of "repeatable" data (however small it is) and it's impact on building quality tools. - thought of building my own scid file(using live T&S data) - which can be used for this purpose(would have solved part of the issue) but you don't want to add the fields bidsize/asksize to scid file(whether you populate or not). So there is absolutely no way for me to replay WITH true bidsize/Asksize information. upcoming feature: Bid/Ask Price & AskSize/BidSize Data | Post: 37653 Thanks Date Time Of Last Edit: 2014-08-06 20:17:24
