Date/Time: Mon, 25 Nov 2024 14:48:09 +0000
rectangle automation
View Count: 202
[2024-02-24 15:52:42]
Bram - Posts: 25
dear Mr, Mrs,
would there be a possibility to have horizontal rectangles automated at a certain time interval. now it's possible to have a H and a L at a certain time interval but it would be nice to have these rectangle area's like You have the time range highlited but then vertical aligned.
many thanks in advance.
Grts Bram
[2024-02-26 16:25:50]
John - SC Support - Posts: 36244
We are not understanding what you are wanting exactly.
If you are able to define a region top and bottom and left and right sides from a study, then you can fill in that region to make it display as a rectangle. Refer to the following:
Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study
