Date/Time: Mon, 25 Nov 2024 14:50:48 +0000
Study needs to be recompiled message
View Count: 266
[2024-02-24 12:42:28]
User248667 - Posts: 8
Hi all,
With the last versions of sierra chart, I get this message:
"Study needs to be recompiled for this version of Sierra Chart"
with every tick update of my chart.
This is quite annoying since it clutters the message log. In the old version it just came up once when opening the chart.
Is it possible to mute this message or to change back to the old situation?
Thanks, kind regards.
[2024-02-24 20:17:12]
Sierra_Chart Engineering - Posts: 17174
We need to see your Sierra Chart Message Log. Instructions:
[2024-02-26 11:05:01]
I have send the message log via the send for analysis button, because it is large.
Thank you.
[2024-02-27 00:18:55]
We have looked into this and this is a custom study:
2024-02-26 05:55:59.770 | DaxTrader Intraday needs to be recompiled for this version of Sierra Chart.
So we recommend recompiling that custom study.
[2024-02-27 16:09:58]
Thank you for your help into this matter.
I know it needs to be recompiled (since sierra charts became 64 bit).
But my question was more about the amount of messages it now generates since a few months.
Kind regards.
[2024-02-27 21:34:30]
Ok we understand, this will be resolved in the next release. There will be much less messages. It would be more than once but significantly less.
[2024-02-27 21:40:33]
That is great! Thanks a lot.
