Date/Time: Mon, 25 Nov 2024 14:43:08 +0000
[User Discussion] - Back Adjusted Gap Fill
View Count: 230
[2024-02-24 07:38:11] |
esMike - Posts: 69 |
Hello, is it possible to do a back adjusted Gap fill with Sierra Chart? It looks like this. The numbers for prior days are adjusted different depending upon the gap, but that just how it works. |
nonFilled.png / V - Attached On 2024-02-24 07:37:27 UTC - Size: 10.14 KB - 51 views backAdj.png / V - Attached On 2024-02-24 07:37:32 UTC - Size: 8.87 KB - 51 views |
[2024-02-24 08:33:57] |
I created a study to do it... Feel free to modify/include it in user contributed studies if you want. SCSFExport scsf_MVNoGaps(SCStudyInterfaceRef sc) { //Copyright @meanVelocity - Free for personal use. SCSubgraphRef Subgraph_Open = sc.Subgraph[0]; SCSubgraphRef Subgraph_High = sc.Subgraph[1]; SCSubgraphRef Subgraph_Low = sc.Subgraph[2]; SCSubgraphRef Subgraph_Last = sc.Subgraph[3]; SCSubgraphRef Subgraph_Volume = sc.Subgraph[4]; SCSubgraphRef Subgraph_NumTrades = sc.Subgraph[5]; SCSubgraphRef Subgraph_OHLCAvg = sc.Subgraph[6]; SCSubgraphRef Subgraph_HLCAvg = sc.Subgraph[7]; SCSubgraphRef Subgraph_HLAvg = sc.Subgraph[8]; SCSubgraphRef Subgraph_BidVol = sc.Subgraph[9]; SCSubgraphRef Subgraph_AskVol = sc.Subgraph[10]; SCFloatArrayRef barDate = sc.Subgraph[11].Arrays[0]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "MV NoGaps"; sc.StudyDescription = "MV NoGaps"; sc.AutoLoop = 1; sc.FreeDLL = 0; sc.DisplayStudyName = 0; sc.DisplayStudyInputValues = 0; sc.GlobalDisplayStudySubgraphsNameAndValue = 0; sc.DisplayAsMainPriceGraph = 1; sc.GraphDrawType = GDT_BLANK; sc.StandardChartHeader = 1; sc.GraphRegion = 0; sc.ValueFormat = VALUEFORMAT_INHERITED; Subgraph_Open.Name = "Open"; Subgraph_Open.DrawStyle = DRAWSTYLE_LINE; Subgraph_Open.PrimaryColor = RGB(0, 255, 0); Subgraph_Open.SecondaryColorUsed = true; Subgraph_Open.SecondaryColor = RGB(0, 255, 0); Subgraph_High.Name = "High"; Subgraph_High.DrawStyle = DRAWSTYLE_LINE; Subgraph_High.PrimaryColor = RGB(128, 255, 128); Subgraph_Low.Name = "Low"; Subgraph_Low.DrawStyle = DRAWSTYLE_LINE; Subgraph_Low.PrimaryColor = RGB(255, 0, 0); Subgraph_Low.SecondaryColorUsed = true; Subgraph_Low.SecondaryColor = RGB(255, 0, 0); Subgraph_Last.Name = "Last"; Subgraph_Last.DrawStyle = DRAWSTYLE_LINE; Subgraph_Last.PrimaryColor = RGB(255, 128, 128); Subgraph_Volume.Name = "Volume"; Subgraph_Volume.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_Volume.PrimaryColor = RGB(255, 0, 0); Subgraph_NumTrades.Name = "NumTrades"; Subgraph_NumTrades.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_NumTrades.PrimaryColor = RGB(0, 0, 255); Subgraph_OHLCAvg.Name = "OHLC Avg"; Subgraph_OHLCAvg.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_OHLCAvg.PrimaryColor = RGB(127, 0, 255); Subgraph_HLCAvg.Name = "HLC Avg"; Subgraph_HLCAvg.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_HLCAvg.PrimaryColor = RGB(0, 255, 255); Subgraph_HLAvg.Name = "HL Avg"; Subgraph_HLAvg.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_HLAvg.PrimaryColor = RGB(0, 127, 255); Subgraph_BidVol.Name = "Bid Vol"; Subgraph_BidVol.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_BidVol.PrimaryColor = RGB(0, 255, 0); Subgraph_AskVol.Name = "Ask Vol"; Subgraph_AskVol.DrawStyle = DRAWSTYLE_IGNORE; Subgraph_AskVol.PrimaryColor = RGB(0, 255, 0); return; } Subgraph_Open[sc.Index] = sc.Open[sc.Index]; Subgraph_High[sc.Index] = sc.High[sc.Index]; Subgraph_Low[sc.Index] = sc.Low[sc.Index]; Subgraph_Last[sc.Index] = sc.Close[sc.Index]; Subgraph_Volume[sc.Index] = sc.Volume[sc.Index]; Subgraph_NumTrades[sc.Index] = sc.NumberOfTrades[sc.Index]; barDate[sc.Index] = float(sc.BaseDateTimeIn.DateAt(sc.Index)); if (barDate[sc.Index] != barDate[sc.Index - 1]) { if (Subgraph_Open[sc.Index] > Subgraph_Last[sc.Index - 1] || Subgraph_Open[sc.Index] < Subgraph_Last[sc.Index - 1]) { float gapAmount = Subgraph_Open[sc.Index] - Subgraph_Last[sc.Index - 1]; for (int Index = sc.Index - 1; Index > 0; Index--) { Subgraph_Open[Index] = Subgraph_Open[Index] + gapAmount; Subgraph_High[Index] = Subgraph_High[Index] + gapAmount; Subgraph_Low[Index] = Subgraph_Low[Index] + gapAmount; Subgraph_Last[Index] = Subgraph_Last[Index] + gapAmount; } } } sc.CalculateOHLCAverages(); } Date Time Of Last Edit: 2024-02-24 08:36:45
[2024-02-26 16:19:26] |
John - SC Support - Posts: 36244 |
The definition of a back-adjusted Continuous Futures Contract option is that it fills that gap by moving the data. Refer to the following: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons And refer to the following for how you can control the amount of the back-adjustment: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-27 07:37:45] |
No, I’m creating full back adjusted charts. So if you set session time to 9:30am to 4PM, there will be no gaps, or even 9:30 to 12:00, it will back adjust and remove all gaps.
