Date/Time: Mon, 25 Nov 2024 15:02:39 +0000
[Programming Help] - Study: Horizontal Lines At Increment (Round to Tick)
View Count: 274
[2024-02-24 02:09:32]
User688525 - Posts: 257
Can assistance please be provided to add "Round to Tick" functionality to the "Horizontal Lines At Increment" study?
I have added
SCInputRef Input_RoundToTickSize = sc.Input[3];
and
Input_RoundToTickSize.Name = "Round To Nearest Tick Size";
Input_RoundToTickSize.SetYesNo(0);
to the "Horizontal Lines At Increment" code in "Studies7.cpp":
#include "sierrachart.h"
SCDLLName("Horizontal Lines At Increment v2")
SCSFExport scsf_HorizontalLinesAtIncrementv2(SCStudyInterfaceRef sc)
  const int NumberOfLines = SC_SUBGRAPHS_AVAILABLE - 1;
  SCInputRef Input_StartValue = sc.Input[0];
  SCInputRef Input_LineIncrement = sc.Input[1];
  SCInputRef Input_SetAllSubgraphsToBeSameAsFirst = sc.Input[2];
  if (sc.SetDefaults)
    sc.GraphName = "Horizontal Lines At Increment v2";
    sc.ValueFormat = VALUEFORMAT_INHERITED;
    sc.DisplayStudyInputValues = false;
    sc.ScaleRangeType = SCALE_SAMEASREGION;
    sc.GraphRegion = 0;
    for (int SubgraphIndex = 0; SubgraphIndex < NumberOfLines; SubgraphIndex++)
      sc.Subgraph[SubgraphIndex].Name.Format("Line%d", SubgraphIndex + 1);
      sc.Subgraph[SubgraphIndex].DrawStyle = DRAWSTYLE_LINE;
      sc.Subgraph[SubgraphIndex].PrimaryColor = RGB(0,255,0);
      sc.Subgraph[SubgraphIndex].DrawZeros = false;
      sc.Subgraph[SubgraphIndex].DisplayNameValueInWindowsFlags = false;
    Input_SetAllSubgraphsToBeSameAsFirst.Name = "Set All Subgraph Display Settings to Be Same as First";
    Input_SetAllSubgraphsToBeSameAsFirst.SetYesNo(false);
    Input_StartValue.Name = "Start Value";
    Input_StartValue.SetFloat(0);
    Input_LineIncrement.Name = "Line Increment";
    Input_LineIncrement.SetFloat(1);
    return;
  for(int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++)
    float CurrentLineValue = Input_StartValue.GetFloat();
      if (sc.Subgraph[SubgraphIndex].DrawStyle == DRAWSTYLE_IGNORE)
        continue;
      if (sc.IsFullRecalculation
        && BarIndex == 0
        && Input_SetAllSubgraphsToBeSameAsFirst.GetYesNo()
        && SubgraphIndex > 0)
        sc.Subgraph[SubgraphIndex].DrawStyle = sc.Subgraph[0].DrawStyle;
        sc.Subgraph[SubgraphIndex].PrimaryColor = sc.Subgraph[0].PrimaryColor;
        sc.Subgraph[SubgraphIndex].LineStyle = sc.Subgraph[0].LineStyle;
        sc.Subgraph[SubgraphIndex].LineWidth = sc.Subgraph[0].LineWidth;
        sc.Subgraph[SubgraphIndex].LineLabel = sc.Subgraph[0].LineLabel;
      sc.Subgraph[SubgraphIndex][BarIndex] = CurrentLineValue;
      CurrentLineValue += Input_LineIncrement.GetFloat();
Thank you
[2024-02-26 04:42:26]
With the above, I would like round to the nearest tick size AFTER the levels have been calculated based on the increment, not beforehand, as this will result in each level increasing/decreasing based on the increment from a rounded level.
