Date/Time: Mon, 25 Nov 2024 14:49:32 +0000
Update ARM 64 version of Sierra Chart
View Count: 468
[2024-02-24 00:37:36] |
User835837 - Posts: 6 |
How do I update my Sierra Chart to the latest version on my MacBook pro M1 ...Im currently running version 2590 ARM on parallels.
[2024-02-24 06:15:30] |
Sierra_Chart Engineering - Posts: 17174 |
Refer to: Software Download: Fast Update If that does not work use the ZIP installer which is listed on that same page as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-26 18:29:58] |
After fast updating, copy trade is not working. Please help
[2024-02-26 19:42:22] |
This is too vague for us to help with. We need more details.
