Date/Time: Mon, 25 Nov 2024 14:50:25 +0000
Vwap 1std deviation
View Count: 267
[2024-02-23 21:48:11]
YAG86 - Posts: 12
HI SC team. could you please help me with the below:
I want to know at any given time the distance (price) of 1 std dev. from vwap. could you please let me know how to set this up
[2024-02-23 21:49:33]
YAG86 - Posts: 12
let me add, that when I said "price" I meant for instance how many points away is 1 std. dev. from vwap.
[2024-02-23 22:00:14]
John - SC Support - Posts: 36244
The "Volume Weighted Average Price" study has the ability to display lines a set number of Standard Deviations from the main price. Refer to the information here:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines
If you are asking how to specifically view the number of points in some way, then you could use a combination of the "Study Subgraphs Difference" and the "Text Display from Study". Where you would reference the VWAP and the first standard deviation lines in the "Study Subgraphs Difference" study to get you the number of points, then reference that result in the "Text Display from Study" to get a large view of the current bar's point difference. Refer to the following:
Study Subgraphs Subtract/Difference
Text Display For Study
[2024-02-23 23:05:13]
YAG86 - Posts: 12
fantastic!!! thanks!
[2024-02-25 23:34:43]
User303857 - Posts: 74
Take a look at this from Simple Systemtrading Sierra Chart, it may help you.
https://www.youtube.com/watch?v=v5GtyPV3g8c
