Date/Time: Mon, 25 Nov 2024 14:47:21 +0000
SMS Activation Code not received
View Count: 242
[2024-02-23 18:45:42] |
User130696 - Posts: 88 |
Can you please clarify, for the live trading using Sierra using Denali data feed and Teton Routing, can I use my AMP Brokers account and how? AMP forces traders to use their own data feed, mostly CQG. Did they allow using their account via some API connectivity not to use CQG or any of their data providers?
[2024-02-23 18:49:09] |
John - SC Support - Posts: 36244 |
Yes, you can use our Teton Order Routing with AMP. And when using our Teton Order Routing, you will have to get your data from our Denali Exchange Data Feed. This is not a problem, just tell them that you want to be setup with the Teton Order Routing.
[2024-02-27 02:37:10] |
Hello, There are too many posts.Thank you for replying to each. I got AMP Teton Routing Enabled for my Sierra Account. How can I enable this with Denali feed ? Along with AMP futures account, can I use Interactive brokers futures accounts for trading once package 11 is enabled ? Date Time Of Last Edit: 2024-02-27 04:00:47
[2024-02-27 16:05:02] |
Yes, you can do this. The way to do this is to have 2 separate installations of Sierra Chart. One that is setup with AMP and the other with Interactive Brokers. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Also, the instructions to setup one installation for the Teton Order Routing is at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions And the instructions to connect the other installation to Interactive Brokers is at the following link: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
