Date/Time: Mon, 25 Nov 2024 14:39:24 +0000
SMS Activation Code not received
View Count: 157
[2024-02-23 18:36:26] |
User130696 - Posts: 88 |
If you see the screenshot of the chart attached to the DOM, you will notice that because of the resolution of the chart, price is incrementing by 10 handles. When I hover the mouse over Buy or Sell columns it moves per tick, but does not display the exact price at the mouse cursor. That does not give confidence in placing order while looking at the bigger picture in the attached chart to the left. I think there should be a way to display the exact price at mouse cursor in some tool tip or other display in the price column. Please let me know. |
Screenshot 2024-02-22 at 5.22.59 PM.png / V - Attached On 2024-02-23 18:36:22 UTC - Size: 684.08 KB - 39 views |
[2024-02-23 18:38:11] |
John - SC Support - Posts: 36243 |
In order to see the price level where the cursor is located turn on the "Crosshairs" from the Tools menu. This will give you the price in the Price Ladder where the cursor is located. Refer to the following: Chart Drawing Tools: Chart Values/Crosshair For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-23 18:38:36
