Date/Time: Wed, 27 Nov 2024 06:39:32 +0000
Log error
View Count: 1010
[2014-08-06 00:58:28]
User021827 - Posts: 174
Warning: Caught an exception during the processing of a timer event. | 2014-08-05 20:56:52
what might this refer to ?
regards
[2014-08-06 01:07:17]
What version of Sierra Chart are you running?
Refer to help topic 17 here:
Http://www.sierrachart.com/index.php?page=doc/helpdetails17.html
[2014-08-06 02:07:46]
hi
ver 1169
also, the chartbook tabs have disappeared and I cant switch between chartbooks . The tabs just left.
I tried to reinstall, but log says up to date and stops
update: reinstalling worked , and I restored tabs setting. Not sure how that got changed.
After reading the link you posted, I checked and think I found the chartbook with auto strategies and spreadsheets that was causing it.
Thank you for the link.
regards
Date Time Of Last Edit: 2014-08-06 02:14:07
