Date/Time: Mon, 25 Nov 2024 14:25:39 +0000
Horizontal lines above and below cursor
View Count: 373
[2024-02-23 15:18:42] |
ssangha84 - Posts: 122 |
Hello, is there any way to have a horizontal line above and below where the crosshair is with the chart values tool? I wanted to have my crosshair with a line 20 ticks below and 20 ticks above to see where my potential stop would be if I entered where my cursor is. Thanks
Date Time Of Last Edit: 2024-02-23 16:05:35
[2024-02-23 17:02:59] |
John - SC Support - Posts: 36241 |
There is not a built-in way to do this. You could develop a custom study to do this. Refer to the following: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-23 17:18:54] |
Ok. What about an option to just have parallel lines drawn 20 ticks above and below another horizontal line in the middle?
[2024-02-23 17:33:25] |
Yes, you can do this. For instance, if you have a drawn Horizontal Line, then you can have two lines associated with that above and below, and they will move as you adjust the horizontal line. There are several ways to accomplish this, but we feel the easiest is to use two copies of the "Spreadsheet Formula" study. To do this, draw a horizontal line using the Drawing Tools. Then open the properties for that line and select the "Anchor" tab. Find the ID of that line and note it. Close the properties window. Then add a Spreadsheet Formula study to the chart and enter the following for the formula: =UDID[1].A1 + 20 * TICKSIZE Where the 1 in the square brackets is the ID of the drawing without the negative sign (i.e. ignore the sign, it's the absolute value, if that is an easier way to think of it). Repeat to put a line below by 20 ticks (changing the + to a -). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-23 17:42:21] |
Ok great, that seemed to work. But is there a way to have a button for a permanent ID for the horizontal line so I wouldn't have to type in that formula every time?
[2024-02-23 19:19:24] |
There is not a way to have a "permanent ID", but that is why we suggested the drawing, as you can move it around to where you want, or even hide it. You could use the "Horizontal Lines" study to put a line and then reference the subgraph from that for the Spreadsheet Study. Depending on how you are using this, it might be an option. Refer to the following: Horizontal Lines Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
