Date/Time: Mon, 25 Nov 2024 14:24:55 +0000
Moving to Break Even with Other Stop Orders Not Triggered
View Count: 207
[2024-02-23 15:04:53] |
Alex Shterenberg - Posts: 9 |
Hi Guys I am having an issue, I am not sure if it is something that is not possible or a user error. Here is the situation, I place 2 stop orders, one to buy above a previous bar high the other to sell below the previous bar low at the same time. When the buy order gets triggered FIRST and continues up I can move my stop loss to break even. When the sell order gets triggered FIRST but not the buy order, and then continues further down, I cannot move my stop loss to break even. Let me know if you need screenshots or any more info. |
[2024-02-23 15:24:27] |
Sierra_Chart Engineering - Posts: 17173 |
Are there any order rejections after moving the order? They will be listed in Trade >> Trade Service Log.
[2024-02-24 03:33:42] |
Hi, yes it does give me a rejection in the Service Log it says; Status not valid to move Stop to breakeven|Symbol:[Sim]MNQH23_FUT_CME|TradeAccount:Sim1|InternalOrderID:6030|Current Status:Pending Child-Client Thank You |
[2024-02-24 06:09:09] |
Yes you cannot move a pending child order to break even, by using the move to breakeven command. The parent order has to fill first. You can manually modify the order though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-24 06:09:21
