Date/Time: Mon, 25 Nov 2024 14:48:03 +0000
Possible to use Quote Board to change displayed symbol and trading symbol?
View Count: 194
[2024-02-23 14:13:11]
User656492 - Posts: 143
If not, this would be a terrific enhancement.
I'd like to click on a symbol on a quote board, say AAPL or ESH4.
I'd like that to set the symbol on linked charts to AAPL and trading symbol to STK-AAPL-SMART.
Maybe I'd also like to click on ESH4 and set the chart to display ESH4 and set the trading symbol to MESH4.
Is this possible to do today?
[2024-02-23 16:31:49]
John - SC Support - Posts: 36244
Yes, you can do this. Refer to the following:
Getting Quotes: Changing Symbol of a Chart or Trade DOM
[2024-02-23 18:11:25]
Doe that require setting a Trade Symbol for each individual equity & futures symbol?
[2024-02-23 19:30:24]
If you want a specific "Trade and Current Quote Symbol" when you change the symbol, then yes, you would have to update or define symbol settings to have the "Trade and Current Quote Symbol" setup as you want for the main symbol. Refer to the following:
Global Symbol Settings: Instructions
[2024-02-23 19:44:24]
There's a whole lot of equities and a handful of futures out there.
Is it possible to translate like this?
SYM ---> *-STK-SMART-USD
[2024-02-23 21:12:18]
There is some support for replacement characters in the Trade and Current Quote symbol, specifically ? for the contract month and # (or ##) for the 1 (or 2) digit year, but this only works for futures. There is not a way to do this for the generic stock symbols (like ???? that is the symbol settings used for any 4 character stock, such as AAPL).
