Date/Time: Mon, 25 Nov 2024 14:37:48 +0000
Candle Time Length in Bar Duration - Number Bars Calculated Values
View Count: 177
[2024-02-23 08:14:51] |
User987212 - Posts: 1 |
Hello I am using a range chart and want to display the time length of the candles in "Number Bars Calculated Values". Unfortunately, only a "zero" appears there and no time value as desired in "min - sec" (see picture attachment) Can anyone help me? |
Bar Duration in Number Bars Calculated.PNG / V - Attached On 2024-02-23 08:10:24 UTC - Size: 7.97 KB - 48 views Attachment Deleted. |
[2024-02-23 16:29:03] |
John - SC Support - Posts: 36243 |
On the Numbers Bars Calculated Values study, it looks like you have the setting for "Use Default Number Formatting For All Subgraphs" set to "No". In order to view the time for the bar, this needs to be set to "Yes", as the time is a specially handled item. If you are curious, the values are really there, but time in Sierra Chart is handled as a fractional time of the day, so the numbers will be very small (on the order of 0.0001). So with the Input above set to No, you would have to change the Value Format to something that shows a lot of decimal places in order to see the underlying value. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
