Date/Time: Mon, 25 Nov 2024 14:53:40 +0000
CQG enabled brokerage, Denali Data Feed and Spreads
View Count: 193
[2024-02-23 07:15:15]
User846000 - Posts: 27
If I select standard CQG symbols from Find Symbol window, I dont get the option to "Get Spreads". If I use the "Futures Spreads - NYMEX (Denali Data)" symbols there is no data for the spread. I assume there must be a mismatch between the symbols, I've updated symbols etc from server but nothing works to bring data in from the Denali feed for spreads.
Anything wrong with this set up other than CQG?
[2024-02-23 15:20:51]
Sierra_Chart Engineering - Posts: 17174
For information about this, refer to:
Denali Exchange Data Feed: Using Denali Futures Spread Data with Trading Service
Make sure you select a specific underlying symbol, in the symbol list and the Get Spreads button will be enabled.
Date Time Of Last Edit: 2024-02-23 15:22:01
