Date/Time: Mon, 25 Nov 2024 14:27:45 +0000
Displaying Volume/Sec for Multiple Symbols Without opening multiple charts
View Count: 245
[2024-02-23 01:29:30] |
User601016 - Posts: 14 |
Hi I want to display Volume/sec for multiple symbols(10-15 symbols). Is it possible to do it without having to create multiple charts(ie. without opening 1 chart/symbol)? for example : MSFT 50/sec NVDA 100/sec GOOG 45/sec Also how can I display these on a single window/graph? I know (reading in SC forums) that using Studies>> calculation Grid and Summation of study subgraphs-periodic, i can display volume/sec subgraph for current symbol. Just want to scale it to 10+ symbols on 1 chart. Thank You! |
[2024-02-23 16:14:45] |
John - SC Support - Posts: 36241 |
You do need to have multiple charts open. Each chart would need to be set to 1 second bars and have a Volume study. You can then use the Study Summary to view this data: Study Summary Window You could also add a Moving Average to each chart in order to get an average of the Volume Per Second. There are multiple Moving Average studies available. And finally, there is a "Volume/Second" calculation in the "Numbers Bars Calculated Values" study. This gives the average volume per bar, so you could use something other than 1 second bars for the charts and then you could use a Moving Average on this information as well. Refer to the following: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
