Date/Time: Mon, 25 Nov 2024 14:31:31 +0000
Trading 10 accounts and copying each account issue
View Count: 287
[2024-02-22 23:58:28] |
Jimmyz83 - Posts: 51 |
As I am copying the trades in 10 accounts, I have had multiple times where the order might not fill or the stop might not work for what ever reason. Is there a place in the software where I can close all positions and orders for all 10 accounts at one time? If I try to flatten all from the parent account, it does not work. Thanks for the help.
[2024-02-23 16:06:36] |
John - SC Support - Posts: 36242 |
There is a Control Bar option that you can setup for "Trade Flatten All Positions - All Accounts". It is under the "Trading Commands" section.
[2024-02-24 06:20:04] |
Sierra_Chart Engineering - Posts: 17173 |
We want you to update Sierra Chart to the current version:Software Download: Fast Update You are running an older version. You may not have this problem in the newer versions when using the Order Allocation to Trade Accounts functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-24 06:20:33
