Date/Time: Wed, 27 Nov 2024 06:48:49 +0000
[User Discussion] - spreadsheet question
View Count: 1064
[2014-08-05 19:18:50]
User021827 - Posts: 174
Hi
How would you flatten positions at a certain time with spreadsheet trading ?
regards
[2014-08-05 19:33:18]
vegasfoster - Posts: 444
Try this,
In I90, "FLATTEN HOUR="
In J91, "FLATTEN MINUTE="
In J90, enter hour you want to exit, from 0 to 23
In J90, enter minute you want to exit, from 0 to 59
In J29, =IF(TIME(DAY(A3),HOUR(A3), MINUTE(A3)) >= TIME(DAY(A3),HOUR(J90), MINUTE(J91)), TRUE, FALSE)
Or could simply replace HOUR(J90) and MINUTE(J91) with desired figures, e.g. for 1:00 p.m. would use,
In J29, =IF(TIME(DAY(A3),HOUR(A3), MINUTE(A3)) >= TIME(DAY(A3), 13, 0)), TRUE, FALSE)
[2014-08-05 19:48:12]
Thanks Vegas !
what happens with vegasfoster, stays with vegasfoster !
best regards
[2014-08-05 22:28:02]
One thing, it will only update with an incoming tick, so if you have to be flat by a certain time, then you may want to set it before. How long before will depend on the instrument and type of bar chart you are using :-P
[2014-08-05 23:19:51]
hi
Ok, thanks again
good info
shane
[2014-08-05 23:53:51]
Where can I read about I90 and J90 cells being used for flatten
thanks
shane
Date Time Of Last Edit: 2014-08-05 23:58:46
[2014-08-06 02:59:58]
Sawtooth - Posts: 4120
This is what I use, in cell J29:
=J41-INT(J41)>TIMEVALUE("15:59:00")
