Date/Time: Mon, 25 Nov 2024 15:01:57 +0000
Pullling Stacking problem
View Count: 248
[2024-02-22 21:50:54] |
KevinDiard - Posts: 18 |
Hello, for some time now, I have noticed that my pulling stacking is distorted in real data, but works well in replay. You can see the pictures I send you. As you can see, in replay a big unloading at the bid, and in real time, the pulling stacking does not change, it is completely different. The 2 captures were taken at exactly the same time. Thanks for your help ! Kévin |
pulling stacking real time.png / V - Attached On 2024-02-22 21:50:45 UTC - Size: 261.44 KB - 53 views Pulling stacking replay.png / V - Attached On 2024-02-22 21:50:50 UTC - Size: 41.93 KB - 51 views |
[2024-02-22 21:52:49] |
John - SC Support - Posts: 36244 |
The Pulling/Stacking is a picture at that moment. Therefore what you see will never be 100% accurate, as things are constantly changing at different rates. The replay is working on data that is more "ordered" and therefore will give a difference versus what is seen in real-time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
