Date/Time: Mon, 25 Nov 2024 15:02:34 +0000
Portable setup
View Count: 271
[2024-02-22 21:10:12] |
User732858 - Posts: 4 |
Hello, My main trading station is at home running nicely on Sierra but I'm spending 60% on my time on the road traveling. I have macBook Pro The sierra does not run on Mac osX right? Would it be possible to use parallels, crossover etc? If I need to buy PC laptop, can you recommend a travel setup to use Sierra with multiple screens? Like flip-out monitors, what would be PC laptop requirements? thanks Kaspar Date Time Of Last Edit: 2024-02-23 07:50:40
[2024-02-23 07:49:36] |
The sierra does not run on Mac osX right? Would it be possible to use parallels, crossover etc? |
[2024-02-23 16:23:58] |
John - SC Support - Posts: 36244 |
Sierra Chart does not run on MAC OS directly. You would have to use some kind of emulator. This is not something we can help with. There are several posts in this Support Board on the topic of installing and using Sierra Chart on a MAC with various emulators. Search the board to see what has been posted already on this topic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-23 23:10:21] |
User752602 - Posts: 9 |
Run it on your current setup at home, then use Remote Desktop to connect to your home pc. This way you don't need to install anything on the MAC. FYI, there are remote desktop clients for phone/iPad also. |
