Date/Time: Mon, 25 Nov 2024 14:47:57 +0000
draw dom on graph on chart replay mode
View Count: 187
[2024-02-22 20:22:26] |
User553413 - Posts: 60 |
Can you help me to add the draw dom on graph function to the chart replay mode? I want to use the draw dom on chart tool for chart replay.
[2024-02-23 15:31:46] |
John - SC Support - Posts: 36244 |
The general information for having the DOM Graph displayed is at the following link: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) If you are not getting the full number of levels during the replay, then refer to the following: Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
