Date/Time: Mon, 25 Nov 2024 10:50:03 +0000
[Programming Help] - ACSIL: how to set Copy chart drawings from chart
View Count: 239
[2024-02-22 18:48:47]
User840964 - Posts: 46
Is it possible to set the above parameter via ACSIL?
Also, is it possible to link it among charts in the same chartbook?
That would be very useful when using charts with different time frames for the same ticker, that's very common.
Else the user is forced to repeat many times the same setting, for many charts and for many chartbooks.
Many thanks
[2024-03-02 13:29:05]
I'd like to put that command in a button.
[2024-03-10 13:04:45]
Which is the minimum time to wait for an answer from your support service?
