Date/Time: Mon, 25 Nov 2024 14:53:40 +0000
Uploaded Footprint charts come out squished
View Count: 473
[2024-02-22 18:14:06]
mojsterr - Posts: 26
Whenever I take a trade, I upload the pictures to the site via the right-click 'Upload chart' option in Sierra. The only problem is the Footprint charts come out squished and the image is not visible like it should be. Something happens that compresses the visual style. I see the image dimensions are smaller the first time around, and the second try is always bigger.
When I try to upload the same picture again, it then comes out normal.
Below are the before and after examples (disregard the arrow, it's just for my entry):
The first (weird) upload
https://www.sierrachart.com/image.php?Image=1708624787882.png
The second (normal one)
https://www.sierrachart.com/image.php?Image=1708625199133.png
It's just annoying uploading the same chart multiple times every time, to get a normal picture.
Any idea why this might be?
Thank you
Edit: I just found out it's not just the Footprint charts. Some others as well, but it's always random.
Date Time Of Last Edit: 2024-02-22 18:25:38
[2024-02-22 18:46:48]
John - SC Support - Posts: 36244
What command are you using to save the image (what is the exact command that you have set for that right-click option)?
[2024-02-22 18:51:36]
The option name is simply 'Upload Chart'
Date Time Of Last Edit: 2024-02-22 18:52:29
[2024-02-22 19:12:16]
For example, I just tried uploading them again, to see what happens (I uploaded 5 different windows, 3 separate regular charts (m5, m15, H1) and 2 Footprint charts (m5 and m15) and 3 were normal, 2 were "squished".
Edit: I tried it again. Went to each window, moved the chart around a bit with the hand tool and clicked "Upload Chart". Now 3 were squished, 2 were ok.
Date Time Of Last Edit: 2024-02-22 19:51:45
[2024-02-22 20:08:22]
I might have found the issue. It might be something to do with the speed when you try to go and upload the next chart.
I tried this several times now. If I click 'Upload Chart' and then wait for the confirmation window, where it says to click 'Yes' to copy it into the clipboard - and I do this slow way for all the others - they all seem to come out ok.
But I wanted to do it quickly to save me some time, and before the confirmation window on the first chart opened, I already went to the next chart window and again quickly clicked 'Upload Chart' on that one. And I then went to the third chart window. But before I could click 'Upload Chart' there, I was already greeted with two separate confirmation windows from the previous two, one after the other, to click Yes to.
I guess something happens and it disrupts the normal uploading if I don't wait for the confirmation window first
Edit:
Yes, this seems to be the issue. I tried it several times and when trying to upload two charts quickly in succession, the first one always comes out in a smaller resolution.
I tried them in reverse this time just to confirm and this is how they look. 1st and the 3rd are squished. The 5th would be as well, but there is no 6th after it, so it had normal time to upload.
1st
https://www.sierrachart.com/image.php?Image=1708632714680.png
2nd
https://www.sierrachart.com/image.php?Image=1708632717408.png
3rd
https://www.sierrachart.com/image.php?Image=170863272514.png
4th
https://www.sierrachart.com/image.php?Image=1708632728370.png
5th
https://www.sierrachart.com/image.php?Image=1708632736575.png
Date Time Of Last Edit: 2024-02-22 20:23:18
[2024-02-22 23:11:54]
Sierra_Chart Engineering - Posts: 17174
You do have to wait for the chart to actually be captured and uploaded before using Screen Images >> Upload Chart command again.
[2024-02-23 06:44:17]
I guess. I thought it just does them one by one in a queue.
Good to know.
[2024-02-23 15:10:32]
You do have to keep the specific chart in the state you want it at.
Date Time Of Last Edit: 2024-02-23 15:10:41
