Date/Time: Mon, 25 Nov 2024 15:23:45 +0000
Data is frozen
View Count: 158
[2024-02-22 16:35:45]
Jason Mcneir - Posts: 11
Hello!
I was trading this morning for about 2 hours, after I was done I logged off but I forgot to check something out in the market. When I logged back in my data was frozen, there was no error message and everytime i tried to reconnect or delete & re download the data it would stay the same.
[2024-02-22 18:39:43]
John - SC Support - Posts: 36245
First, refer to the following for the items to look into:
If you continue to have an issue after going through the above, then get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
