Date/Time: Mon, 25 Nov 2024 15:41:34 +0000
CL data
View Count: 187
[2024-02-22 16:31:36] |
TEvans622 - Posts: 3 |
Hi im just checking do i have access to CL data? i just asked my broker amp and they said to ask you as they only do order routing
[2024-02-22 18:29:56] |
John - SC Support - Posts: 36245 |
You are not setup to get the data for CL from us. You have the following exchange activated: - CME With Market Depth for Non-Professional Trading Accounts CL is traded on the NYMEX exchange, so you would need to add/change your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Keep in mind the exchange fees are not pro-rated, they renew on a calendar month basis, and they are not refundable. Therefore, if you add a new exchange option, you will pay the full amount for it regardless of when, within the month, you add it - You will then pay again on the first day of the following month. If you deactivate an exchange, you will not get a refund, but you will still have access to the data through the remainder of this month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
