Date/Time: Mon, 25 Nov 2024 15:49:49 +0000
[User Discussion] - colored line in the Chart between Entry and Exit
View Count: 212
[2024-02-22 16:03:25]
User417891 - Posts: 2
Please can you explain how I can set, that there will be a red line in the chart between entry and exit, if it was a loss trade,
and a green line between entry and exit, if it was a winning trade.
Now I see triangles and text fields. I want to keep the triangles, but to hide the text fields. Thank you in advance for your help.
[2024-02-22 16:37:01]
Sawtooth - Posts: 4120
Go to Global Settings >> Graphics Settings > Colors and Widths tab, and scroll down to Chart Trading Order Fills.
imageEntryExitConnectingLines.PNG / V - Attached On 2024-02-22 16:36:57 UTC - Size: 24.36 KB - 41 views
[2024-02-22 18:41:15]
John - SC Support - Posts: 36245
To define what is shown in the Order Fills line, refer to the following:
Global Trade Settings Windows: Order Fills (Global Settings >> Chart Trade Settings >> Order Fills)
