Date/Time: Mon, 25 Nov 2024 15:36:52 +0000
Missing formula in STUDY ANGLE spreadsheet?
View Count: 199
[2024-02-21 22:45:55]
jivetrader - Posts: 410
Study Angle
provides a spreadsheet with the formulas for the STUDY ANGLE study. On sheet TEST, cell D13 is a number, not a formula. This number becomes an input to E13, etc. Could you please provide the initial formula for D13 so that this study can be reconstructed in a separate spreadsheet? Thank you.
Also, which output becomes the SG1 for the STUDY ANGLE study: angle, theta, diff theta, or % diff theta?
Date Time Of Last Edit: 2024-02-21 22:48:23
[2024-02-22 16:22:59]
John - SC Support - Posts: 36245
D13 is the value from the study itself. E13 is the calculated value. Column E does not use the D column for any Input.
Column E is also the same value as the data in the subgraph from the study.
