Date/Time: Mon, 25 Nov 2024 15:26:35 +0000
Missing Market data
View Count: 202
[2024-02-21 21:14:52]
User679705 - Posts: 1
My charts are missing to fill some areas with volume
imageScreenshot 2024-02-21 195701.png / V - Attached On 2024-02-21 21:14:40 UTC - Size: 5.19 KB - 45 views
[2024-02-22 16:02:13]
John - SC Support - Posts: 36245
If you are referring to the gap that is in your chart, then check your Session Times to ensure that you are viewing the full range of time for which the product is traded.
Otherwise, refer to the following for how to redownload data that is missing in your chart:
