Date/Time: Mon, 25 Nov 2024 15:50:58 +0000
User Discussion: Text/CSV Data Format
View Count: 172
[2024-02-21 19:34:18]
sgne - Posts: 105
Has anyone gotten this to work for them? I have been trying to use this recently but have failed to generate a chart that shows the values of the intraday text file. I have even used data exported from Sierra Chart and the example provided online.
If someone has gotten it to work, what are the things to do to make it work, which aren't explained on the webpage?
Here are a few things I've noticed. Spaces after the delimiter are needed in the text file. It says to load as a historical file, so even though it might clearly be an intraday file, it loads like a daily. In Chart Settings, it even says it's an intraday file, but the chart doesn't treat it as one. If you rename it with a csv extension and open it as an intraday file, it still treats it like a daily file.
