Date/Time: Mon, 25 Nov 2024 15:34:33 +0000
Trade Management using Heikin-Ashi Bars
View Count: 367
[2024-02-21 18:01:54]
TheMatadorTrader - Posts: 21
Good trading to all!
I have set up the Trade Management Indicator to trail my entry to the previous HA candle high/low and it works flawlessly. My question is can the Trade Management indicator be adjusted to allow for # of bars to trail?
For example when the market is trending and to stay in a trade during a minor pullback can I set the manager to trail by 2 or 3 bars instead of just the previous bar?
Thanks in advance!
[2024-02-21 18:43:14]
John - SC Support - Posts: 36245
To do this you would need to use the "Study Subgraph Reference" and use it as the proxy for the actual item you want to reference (e.g. the HA High), then you can use the "Displacement" option in the Subgraph to "move" the value of the bar 2 (or 3) back to the front bar and the "Trade Management by Study" will then be off that value. Refer to the following:
Chart Studies: Subgraphs Tab >> Displacement
