Date/Time: Mon, 25 Nov 2024 15:23:45 +0000
How to See Rollover Gaps for Futures?
View Count: 208
[2024-02-21 16:41:50] |
User450463 - Posts: 123 |
Not sure I'm saying this right, but I want set up a chart so that ES prices are not "continuous"? In other words, I want to see rollover gaps on my ES chart. I believe some people refer to this as not using "back adjustment".
[2024-02-21 17:57:28] |
John - SC Support - Posts: 36245 |
You still need to use a "Continuous Futures Contract Chart" option, but you will not use one of the "Back Adjusted" options. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
