Date/Time: Mon, 25 Nov 2024 15:26:34 +0000
VbP extending over two days
View Count: 206
[2024-02-21 13:21:13] |
StephenL - Posts: 98 |
Hi guys, how do I stop the volume profile extending across two days. I copied this setting on to the Corn chart just to check and it comes up correctly. Thanks, Stephen |
Screenshot 2024-02-21 131855.png / V - Attached On 2024-02-21 13:21:02 UTC - Size: 86.71 KB - 54 views |
[2024-02-21 17:10:21] |
John - SC Support - Posts: 36245 |
What are the following Inputs for the VbP set to: - Volume Graph Period Type - Time Period Type for 'Fixed Time' - Time Period Length for 'Fixed Time' - Number of Bars for 'Based on Bar Count' - Maximum Volume Bar Width Type - Maximum Volume Bar Width Percentage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-22 13:09:15] |
Hi John, Your reply got me the fix. I had Window Width set to Window Length, instead of Period, and I had Period set at only 5, I've moved it to 100. Thanks for the help. |
Screenshot 2024-02-22 130820.png / V - Attached On 2024-02-22 13:08:49 UTC - Size: 77.81 KB - 52 views |
