Date/Time: Sun, 24 Nov 2024 18:23:35 +0000
[User Discussion] - Calculated values text above/below bars based on thresholds
View Count: 276
[2024-02-21 09:58:46] |
User135088 - Posts: 3 |
Hi, I have been using the calculated values study in conjunction with 2 study subgraph above/below bar as text to display a specific ratio value which works fine. However I would like to either display the value only if it meets a threshold or change the color so I can easily see which values meet the threshold (Example: only show values above 30 and below 1 or color blue if above 30 and red if below 1, etc.). Is there a way to easily accomplish this (wihtout coding anything myself which I am not proficient at yet)? Regards, Dan |
[2024-02-21 16:49:40] |
Attached is a Study Collection that gives you an example where the value from the Numbers Bars Calculated Values is only displayed when the value is greater than 30. This should give you what you need to fill out the rest. Refer to the following for how to use a Study Collection provided by Support: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
DisplayNumbersBarsValuesGreaterThan30.StdyCollct - Attached On 2024-02-21 16:49:36 UTC - Size: 34.36 KB - 191 views |
