Date/Time: Mon, 25 Nov 2024 17:36:08 +0000
how to connect an Apex Rithmic PA account to Sierra Chart ?
View Count: 1169
[2024-02-20 18:24:25] |
powertrader007 - Posts: 2 |
Hello Sierra chart support team, i already have the Sierra package 5 delayed data, but i also have an Apex Rithmic PA account and Apex mentioned that i have to ask you how to connect it to Sierra chart so i could have live data instead of delayed to practice with on sim ! thank you |
[2024-02-20 18:31:01] |
John - SC Support - Posts: 36253 |
In order to be able to connect to a trading or data service, you need to be on one of the "Integrated" packages. Right now, you are on the "Base Advanced" package. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages You can change your package at any time. To do so, select the following link and select the package you want from the menu to the left, then select the "Update/Set" button. When you change your package, we do not give a refund or charge for it, rather we adjust your remaining Usage Time based on the difference in the package pricing. Therefore, if you change to a more expensive package, your remaining Usage Time will go down, and vice versa. https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage Once you have the package worked out, then you can connect to your APEX account by following these instructions: Rithmic Trading Platform Service: Setup Instructions We are not sure what you mean by "how to connect it to Sierra Chart so i could have live data instead of delayed to practice with on sim!" You can get the real-time data from Rithmic through Apex. If that is what you want, then just follow the instructions we gave above. If you are wanting real-time data for the CME Group from our Denali Exchange Data Feed, then you need to have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. And you need to be able to connect to this account at least once a month. Prop Firm accounts (like APEX) do not count towards this requirement. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have another trading account that will fulfill the above requirements, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
