Date/Time: Mon, 25 Nov 2024 15:37:45 +0000
message rate limit reached on simulated feed
View Count: 243
[2024-02-20 17:52:41] |
User61576 - Posts: 443 |
hi can this be controlled in the simulated feed? where / how can I see the value set and the real-time value? what are the rules for this? |
[2024-02-22 00:08:06] |
Sierra_Chart Engineering - Posts: 17174 |
Yes you can control this. You need to first edit the trading account: Trade Account and Risk Management: Edit Trade Account And then adjust this setting: Trade Account and Risk Management: Setting Order Rate Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-22 00:08:30
