Date/Time: Mon, 25 Nov 2024 15:24:24 +0000
brokerage to trade futures AND stocks directly from sierra chart?
View Count: 321
[2024-02-20 15:06:01]
User610117 - Posts: 40
Is Interactive Brokers the only choice? If I use IB, do i lose a lot of the features of Package 10?
Thanks!
[2024-02-20 17:13:27]
John - SC Support - Posts: 36245
Interactive Brokers is the only option for trading stocks. And if you want a single broker for both stocks and futures, then this would mean using Interactive Brokers.
You will not lose any features by using Interactive Brokers, we are curious as to what in particular you are wondering about?
Also, you are getting your futures data from us, so that will help with issues from Interactive Brokers. We recommend getting your stock data from us as well. The instructions for the U.S. Equities is at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
[2024-02-20 19:23:18]
Thank you for the quick response.
TPO and footprint charts was what i was curious about whether i would lose or not.
I would really appreciate anyone with the IB connection to share whether it has been usable for both stocks and futures.
Thanks again!
[2024-02-20 21:29:08]
TPO and Footprint (Numbers Bars) charts are only available with the "Advanced" packages, so if you change to Package 10 (Integrated Standard) you would lose those functions.
[2024-02-22 02:47:11]
So I have closed my futures only account and want to connect my trading to my Interactive Brokers. Under Data/Trade Service Settings, the Sierra Chart forum states to choose " Interactive Brokers (trading)", but how do I continue to rely on getting futures data from Sierra Chart? Is that chosen somewhere else?
Appreciate your help. Would it be possible for a phone call to get this connection setup correctly? I would also like to add the stock data from Sierra as well.
Please let me know and thanks!
[2024-02-22 16:46:55]
To connect to Interactive Brokers, follow the instructions at the following link:
Interactive Brokers Trading Service: Setup Instructions
With regards to getting the data, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
We see that you have data for The CME Group and CFE setup. To setup data for our "U.S. Equities Consolidated Tape" exchange, follow the instructions at the following link:
