Date/Time: Tue, 18 Feb 2025 22:40:21 +0000
New drawing tool properties - minor issues
View Count: 227
[2024-02-20 14:15:25]
User201106 - Posts: 62
Version 2604
Double click on drawing to open properties window.
Click Cancel to exit. The drawing still shows as selected with anchors.
Behavior should be the same as the previous method. Drawing is not shown as selected.
On the Yes/No fields. Please allow a single click in this field to toggle the value.
It takes 2 or 3 clicks to change the value.
The List & Button fields do respond on the 1st click.
[2024-02-20 19:05:04]
Sierra_Chart Engineering - Posts: 18484
We will check on the first item.
Regarding the Yes/No fields and other fields there are settings to control this:
Settings Windows Interface: Changing User Interface Behavior
