Date/Time: Wed, 27 Nov 2024 18:39:42 +0000
CQG Data Feed - Is it enough?
View Count: 1926
[2014-08-05 15:10:20]
User12676 - Posts: 70
On the CQG page it says "Streaming Real-Time Data: Yes".
Then it says
"Historical Intraday Data: Provided by the Sierra Chart Historical Data Service. This data is 10 minutes delayed. To avoid the 10 minute delay, you need to use the Sierra Chart Real-Time and Historical Exchange Data Feed."
I am confused, first it says CQG real time data is supported, then it says you need the Sierra Chart Real-Time Data Feed. If CQG real time data is supported, why do you need Sierra Chart real time feed?
Please explain.
Thanks.
[2014-08-05 15:17:07]
The Sierra Chart Real-time and Historical Exchange Data Feed is needed to avoid 10 minute delayed historical data.
[2014-08-05 15:20:26]
User021827 - Posts: 174
The real time sierra data would be historical data to fill in your charts from this moment forward. The regular sierra historical data fills in the charts from this moment backward, but with a 10 minute delay.
The cqg real time data also fills the chart from this moment forward.
If you open a chart right now, the real time data would populate the chart from this moment forward. The historical data would populate the chart from this moment backward.
I use the regular historical data by sierra and it works just fine for me. In some cases, People do not want the 10 minute gap.
The 10 minute delay is not for real time data, it is for the historical data. In most cases , that does not cause a problem.
[2014-08-05 15:23:34]
If you are with AMP and using CQG, the historical data is no longer delayed by 10 minutes. Update Sierra Chart to the current version with Help >> Download Current Version and set the Global Settings >> Data/Trade Service Settings >> Service to AMP CQG.
Date Time Of Last Edit: 2014-08-05 15:24:44
[2014-08-05 15:24:50]
I see, thanks for the explanation.
So basically, CQG real time data is useless if you need the previous 10 minutes, so you are forced to buy the Sierra Chart Real Time data.
How come Sierra Chart can't download the previous 10 minutes using CQG feed?
[2014-08-05 15:27:58]
What broker/trading service are you using CQG through?
[2014-08-05 15:28:09]
About AMP CQG. Is it ampfutures.com or ampclearing.com? Are they different or both the same?
[2014-08-05 15:28:32]
I'm using deep discount right now. Ill consider switching to AMP if the data is provided
[2014-08-05 15:30:14]
AMP Futures and AMP Clearing are the same.
When using Deep Discount Trading, you will need to use the Sierra Chart Exchange Data Feed to avoid the 10 minute delayed historical data.
[2014-08-05 15:32:08]
OK, thanks
[2014-08-05 15:39:57]
The 10 minute delay may not be all that significant for you. Refer to this thread here:
Helpful Trick to Solve 10 Minute Delayed Historical Data
[2014-08-05 16:00:37]
One more question,
With AMP and CQG, is historical data required from Sierra Chart, or can AMP provide this?
[2014-08-05 18:01:42]
When you use CQG through AMP historical data is provided.
[2014-08-05 21:32:24]
Carl71 - Posts: 125
SC,
Would you please to communicate this good news about AMP-CQG in the CQG Trading Platform Service page?
As regards this affirmation: "Data Cost: 10-20 USD / Month + exchange fees. Trading Account is required.", can you explain it better?
Date Time Of Last Edit: 2014-08-05 21:33:23
[2014-08-05 21:59:46]
For information about the cost of CQG you need to contact your broker.
We cannot explain this any better.
[2014-10-01 06:36:31]
Has the 10 min delay been resolved for Deep Discount Trading or is it only for AMP still?
[2014-10-01 07:55:16]
Yes, but only for CME and ICE.
