Date/Time: Sun, 24 Nov 2024 23:34:38 +0000
Default Chart drawing alert
View Count: 315
[2024-02-20 08:55:47] |
Fabio - Posts: 115 |
Good morning, Is there are way to create a different default settings for when I want to have an alert on a drawing? Every time I open the chart drawing alert window, by default, the study sub-graph is set to Open, Comparison to drawing is set to Crossing, etc. Is there a way that, by default, every time I open the chart drawing alert I can have already my preferred setting already instead of the ones just mentioned? Thanks, Fabio |
[2024-02-20 16:17:36] |
Our apologies, there is not a way to do this exactly. But there is the ability to have a specific alert setup for a drawing configuration. Refer to the following: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-27 15:43:43
[2024-04-16 21:31:37] |
mihaly kandra - Posts: 1 |
hi i would like to trade us cocoa futures on us ice but cant find it on sierra charts, can you guys tell me if you provide that market im curently on package 11 many thanks |
[2024-04-17 01:24:25] |
Sierra_Chart Engineering - Posts: 17163 |
At this time Sierra Chart does not provide Intraday or real-time market data for ICE. We do have end of day historical Daily data. You can find the symbols in File >> Find Symbol >> Futures - ICE US/EU For market data and trading you will want to use CQG for ICE: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
