Date/Time: Mon, 25 Nov 2024 17:29:17 +0000
Missng symbol SMCI
View Count: 239
[2024-02-19 20:59:15] |
User3366712 - Posts: 2 |
Hello, I tried updating symbol settings (update from server) and follow the step from sierra web site guide. connect reconnect and chart setting double click apply global symbol settings. still unsuccessfull. I am still missing SMCI symbol from my list. I am using Data feed : SC Data -all services (data) thank you for help |
[2024-02-19 21:27:00] |
John - SC Support - Posts: 36253 |
We do not list, or have symbol settings for every stock symbol. You just have to enter the symbol on the "Find Symbol" window and select the appropriate action button (Open Intraday Chart, Open Historical Chart, etc).
[2024-02-19 23:28:36] |
Maybe I am not being clear. SMCI is not listed in the find symbol list. Super Micro Computer Inc 803.32 USD as I explain I update the list from global settings/symbols settings as stated in sierra chart tutorial and this not help |
[2024-02-20 15:59:50] |
As we stated, we do not list all the symbols for the U.S. Equities, as there are too many of them. You just need to enter the symbol in the "Selected Symbol" field on the "File >> Find Symbol" window and then select the button for what you want to do (Open Intraday Chart, Open Historical Chart, etc.). Refer to the image at the following link: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
