Date/Time: Mon, 25 Nov 2024 16:23:59 +0000
Limit Order Book Display with volume Bars on DOM or Chart
View Count: 312
[2024-02-19 14:43:25] |
Steve Leon - Posts: 301 |
I wanted to display the limit order book as volume bars either on a Trade DOM or a price -time chart. I wanted to be able to see this independently of the the bid/ask size; buy/ask column. When i use the combined bid/ask size i cannot see the original (bid/ask size columns) ? Is there a way to do this ( to display both at same time ? What would you suggest to try to achieve this ? Market Historical Depth Study ? Thank you |
[2024-02-19 17:37:25] |
John - SC Support - Posts: 36248 |
The only other option is the "DOM Graph". Refer to the following: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
