Date/Time: Wed, 27 Nov 2024 06:33:03 +0000
Alert Sounds Not Completely Heard (version 1169)
View Count: 1058
[2014-08-05 14:18:58] |
vrunrun - Posts: 53 |
Hi SC, After upgrade to version 1169, I noticed that any sounds that are queued up, will be immediately played but they will terminate the prior sound playing. This really annoy me as I've set up alert sound in multiple charts to alert me specific pattern/signals, major price level etc. Without full replay of the alert sounds, I don't know what the alert is as I'm not starring at the monitor all the time, which I bet most full-time trader will not do that. Can you make the alert sounds work just like old times or make a option on the alert sound to play the alert completely before playing the next one queued? If not, what version should I down grade to in order to make the alert sounds work just like old times? Pls advise. Thanks. |
[2014-08-07 07:54:33] |
We are aware of this. We are going to be adding an option to either delay the playing of alert sounds if one is playing or immediately play them. We will have that option out by the end of the day tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-08 02:40:56] |
Have installed version 1172 but can't find the sound alert option. Pls advise where I can set it. Thx.
[2014-08-08 05:46:18] |
This will be out in a few more hours. Has not yet been released. The option will be in Global Settings >> General Settings >> Alerts.
