Date/Time: Mon, 25 Nov 2024 16:25:28 +0000
How to setup Telegram Username
View Count: 551
[2024-02-19 00:37:16] |
User396 - Posts: 55 |
I am seeing the error message: "No Number Sent. Failed to send SMS." However, I have correctly configured my Telegram username in Global Settings -> Alerts -> SMS Number/Telegram Username. When I attached the bot, I received the message "Your Sierra Chart chat username is attached successfully." So, I am assuming that the bot is configured correctly. However, If I send a test message via MAIN Chat window, I do not receive in telegram bot. What am I doing wrong? How can I fix this issue? Date Time Of Last Edit: 2024-02-19 00:40:28
[2024-02-19 00:38:46] |
Sierra_Chart Engineering - Posts: 17174 |
Your Sierra Chart account is already active so there is no need to activate it. And Telegram support for alerts is not yet complete.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-19 00:38:55
